Configures the Multicast Listener Discovery (MLD) timers.
| query_interval | Specifies the interval (in seconds) between general queries. |
| query_response_interval | Specifies the maximum query response time (in seconds). |
| last_member_query_interval | Specifies the maximum group-specific query response time (in seconds). |
| vlan_name | Applies the configuration only to the specified VLAN. If no VLAN is specified, the configuration appliese to all VLANs. |
| vr_name | Specifies the VR to which the configuration should be applied. If not parameter is specified, the configuration is applied to the current VR context. |
| robustness | Specifies the degree of robustness for the network. |
The following command configures the MLD timers:
configure mld 100 5 1 3
This command is available on the platforms listed for the IPv6 multicast routing feature in the Switch Engine v33.1.1 Licensing Guide document.
